Toshiba Satellite C55-B5200 Hard Disk Drive Replacement
Introduzione
Vai al passo 1A hard drive replacement guide for a Toshiba Satellite C55-B5200 laptop.
Cosa ti serve
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Remove the two 4.6mm Phillips #0 screws from disk drive.
Lift the disk drive and pull out to remove.
Altre 5 persone hanno completato questa guida.
2 Commenti
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
Dónde puedo comprar el disco duro de una laptop toshiba satellite C55
