Salta al contenuto principale
Toshiba Satellite C55-A5286 Hard Drive Replacement
Nicole Zellers
Nicole Zellers e 2 altri collaboratori
Ultimo aggiornamento il July 14, 2023
10 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to remove or replace the hard drive of the Toshiba Satellite C55-A5286 laptop. A Phillips screwdriver of head size PH0 is required for this guide.
Cosa ti serve
Strumenti
  1. Toshiba Satellite C55-A5286 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Unplug the AC adapter and all other auxiliary components from the laptop.
  2. Toshiba Satellite C55-A5286 Hard Drive Replacement: passo 2, immagine 1 di 1
    • There is a removable panel on the underside of the laptop with one 5-mm screw holding it in place.
    • Use the screwdriver to remove the screw and then remove the back panel.
  3. Toshiba Satellite C55-A5286 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Underneath this panel is a silver square with rubber around the edges. This is the hard drive. On the side of the hard drive nearest to the manufacturer’s label, there is a large, flat 8-mm screw that is holding the hard drive in place.
    • Use the screwdriver to remove the screw.
  4. Toshiba Satellite C55-A5286 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Carefully hold the sides of the hard drive with the rubber and pull the hard drive out. It should remove fairly easily.
Conclusione
Altre 2 persone hanno completato questa guida.
IUPUI, Team S1-G5, Hovde Fall 2018 Membro di IUPUI, Team S1-G5, Hovde Fall 2018
IUPUI-HOVDE-F18S1G5
2 Membri
9 Guide realizzate
Un commento
The hard drive is ‘encased’ in a foil-looking, very flexible ‘enclosure’.
On the screw-side (near the label), each corner of the foil enclosure has a rubber black stuffed between the drive and the laptop - these blocks are connected to the enclosure via a rubber ‘string’. If you pull those nubs straight up, you can pull on them towards the label to disengage the drive from its SATA interface.
William Totman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 37
Tutti i Tempi: 994
