Salta al contenuto principale
Toshiba Satellite C55-A5100 RAM Replacement
Walker Tortorigi
Walker Tortorigi e 3 altri collaboratori
Ultimo aggiornamento il July 8, 2023
5 - 8 minuti
Facile
Introduzione
Vai al passo 1
This guide will walk you through the process to replace your RAM.
Cosa ti serve
Strumenti
  1. Toshiba Satellite C55-A5100 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 RAM Replacement: passo 2, immagine 1 di 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Place the laptop with the bottom facing up.
    • Observe the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 RAM Replacement: passo 4, immagine 1 di 2 Toshiba Satellite C55-A5100 RAM Replacement: passo 4, immagine 2 di 2
    • Using your Phillips #1 screwdriver, unscrew the 6mm screw on the panel, exposing the hard drive and RAM.
  5. Toshiba Satellite C55-A5100 RAM Replacement: passo 5, immagine 1 di 1
    • Once the ram chip is exposed, push the two clips away from the ram chip to release it. (Clips move in direction of arrows.)
  6. Toshiba Satellite C55-A5100 RAM Replacement: passo 6, immagine 1 di 1
    • The ram chip will tilt up after the clips are released.
    • Using your fingers, pull the ram chip out at a slight angle.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 409
