Salta al contenuto principale
Toshiba Satellite C55-A5100 Optical Drive Replacement
Walker Tortorigi
Walker Tortorigi e 5 altri collaboratori
Ultimo aggiornamento il July 8, 2023
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
Replacing the optical drive in a Toshiba Satellite laptop should not be seen as difficult, but does involve opening one of the panels on the underside of the laptop.
Cosa ti serve
Strumenti
  1. Toshiba Satellite C55-A5100 Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 3 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: passo 3, immagine 2 di 3 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: passo 3, immagine 3 di 3
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Optical Drive Replacement: passo 4, immagine 1 di 1
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Optical Drive Replacement: passo 5, immagine 1 di 1
    • Remove the disc drive from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Any idea of how tall the drive is? Is it 12.7mm or 9.5mm tall?
Luis Alejandro Araúz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 375
