Salta al contenuto principale
Toshiba Satellite C50-B-14Z Thermal Pad Replacement
Simeon Brankov
Simeon Brankov e un altro collaboratore
Ultimo aggiornamento il July 5, 2023
25 minuti
Facile
Pallini!
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Hello everyone, in this guide I`ll be showing you how to open the laptop in order to change the thermal pad, as well as to possibly upgrade the RAM and replace the HDD with SSD.
  1. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Opening the laptop.: passo 1, immagine 1 di 2 Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Opening the laptop.: passo 1, immagine 2 di 2
    • Unscrew the 15 screws holding the back panel in place.
    • Use a prying tool to carefully release all the clips.
  2. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Changing the thermal pad.: passo 2, immagine 1 di 2 Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Changing the thermal pad.: passo 2, immagine 2 di 2
    • Unscrew the 4 screws holding the CPU heatsink and fan assembly and lift it up, gently.
    • Disconnect the fan.
    • Replace the thermal pad. Be sure to use the same thickness thermal pad.
  3. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Cleaning the fan.: passo 3, immagine 1 di 1
    • Unscrew the 2 tiny screws that hold the fan assembly together.
    • Clean it with a soft brush and compressed air.
  4. Toshiba Satellite C50-B-14Z Thermal Pad Replacement, Upgrading the RAM and SSD (Optional): passo 4, immagine 1 di 1
    • Once you opened the back cover, it is a good idea to upgrade the SSD and RAM if you want.
    • This model can take up to 8GB DDR3L.
    • You can also put in a CD/DVD Drive or an additional SSD in its place.
Conclusione
Altre 2 persone hanno completato questa guida.
Simeon Brankov
Membro da: 11/08/20
7.180 Reputazione
54 Guide realizzate
Un commento
My toshiba laptop is locked and I enter Enter Password
Florian - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 40
Tutti i Tempi: 495
