Toshiba Satellite A75-S226 Upper Case Replacement
Cosa ti serve
Make sure battery-lock is in the unlock position.
Slide button to the left.
Remove the 5.64 mm screw from the bottom of the crossing bar.
Remove the crossing bar.
Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
Use the Phillips screwdriver to remove the two 3.7 mm screws from the battery compartment.
Then remove the fourteen 8.6 mm screws from the bottom of the case.
