Toshiba Satellite A665-S5170 Battery Replacement
Introduzione
Vai al passo 1If your battery will not retain charge when your computer is unplugged from the adaptor, your battery may be faulty, and you may need to replace it. Replacing your Toshiba Satellite A665-S5170 battery does not require any tools and takes relatively little time.
Cosa ti serve
Turn the computer upside-down so that the bottom of the laptop is facing up.
Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
Altre 2 persone hanno completato questa guida.
