Salta al contenuto principale
Toshiba Satellite A660-ST3NX2X Hard Drive Replacement
Cassie Pickett
Cassie Pickett e 3 altri collaboratori
Ultimo aggiornamento il June 24, 2023
1 - 4 minuti
Facile
Introduzione
Vai al passo 1
This replacement guide is to walk you through a hard drive replacement on your Toshiba Satellite A660-ST3NX2X. Before starting this replacement, make sure you have a replacement hard drive that is made for this computer and model. Also, make sure the computer is powered off and completely shut down before completing this replacement.
  1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 2, immagine 2 di 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 3, immagine 1 di 3 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 3, immagine 2 di 3 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 3, immagine 3 di 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Unplug all devices from your computer and power down the device completely.
    • Flip the computer over so the screen is facing down.
    • In the image, the hard drive will appear to be in the top right corner where the box indicates.
  5. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 5, immagine 2 di 2
    • Use a J00 bit to unscrew the single 4mm screw that holds the hard drive cover in place.
  6. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 6, immagine 2 di 2
    • Remove the cover that holds the hard drive in place.
    • Remove the hard drive.
    • This computer contains no hard drive, therefore we are unable to show the physical removal of it.
Conclusione
Cassie Pickett
Membro da: 03/20/17
201 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 568
