Toshiba Satellite A215 S4697 Hard Drive Replacement
Introduzione
Vai al passo 1Replacing a hard drive is a great yet simple fix. Make sure your new drive is the 2.5" laptop hard drive!
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
Find the battery compartment.
Slide the left slider which is just beneath the battery compartment into its leftmost position.
Locate the hard drive in the left hand corner, and remove the two 4mm Phillips #1 screws.
Altre 14 persone hanno completato questa guida.
2 Commenti
What if I don't have the metal housing
I bought the laptop from someone and it didn't have the metal housing and the laptop just keeps going from startup screen to loading back and fourth can someone help
