Toshiba Satellite 2435-S255 Heat Sink Replacement
Introduzione
Vai al passo 1Remove the Battery. Whenever tinkering with electronics, always turn them off and remove all sources of power if possible; otherwise you could hurt yourself or damage your machine irreparably.
Cosa ti serve
First, slide the latch until you hit resistance. At this point, you have two options.
You can either keep pushing the latch until the battery pops out. . .
or you can start prying the battery out while pushing the latch (as shown in the second picture above).
Just lift the battery up and out, making sure to lift from the end near the latch.
Now the battery is out! To put it back, just insert it back in from the same angle you took it out on.
Using a T6 screwdriver, unscrew the two indicated 4mm screws to remove the panel.
After that, simply lift and pull out the cover panel.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
This step can be kind of tricky. Using a PH00 screwdriver, remove the eight indicated screws. The screws in the four corners are 5mm while the four screws on the left and right sides are 3mm.
If you’re removing one of the top or bottom (red) ones for that side last, make sure to use a pair of tweezers to hold the other end so that the bracket doesn’t drop into the laptop.
To remove the heat sink, pull it away from the fan and up.
Done! The heat sink is out. Check the conclusion for a little information on putting it back in.
When re-installing the heat sink, start with one of the top/bottom screws for the bracket, then do the middle two, and then the last top/bottom one. For the last screw, push down on that end of the bracket so the screwholes line up. Otherwise, follow these instructions in reverse order.
