Toshiba Qosmio X505-Q860 CD Drive Replacement
Introduzione
Vai al passo 1If your disks run on other devices but not this laptop, use this guide to replace the CD Drive.
Cosa ti serve
Strumenti
Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
Pull off the part of the case that's now loose by the indicated tab.
Take out the 4.7mm long JIS #0 screw with a JIS Screwdriver.
The CD Drive is now loose. Pull it straight out of the side.
