Salta al contenuto principale
Toshiba Portege M400 Keyboard Replacement
Varsha Roopreddy
Varsha Roopreddy e 12 altri collaboratori
Ultimo aggiornamento il April 5, 2023
2 - 3 minuti
Facile
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
In this guide, you will learn how to disassemble the broken/damaged keyboard from the rest of the laptop as well as how to replace it. This guide will also teach you what the proper and necessary tools are for this repair.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Toshiba Portege M400 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the front face plate with a plastic opening tool.
    • Unscrew and remove the two 3.8mm screws labeled B3 with the #1 Phillips screwdriver.
  2. Toshiba Portege M400 Keyboard Replacement: passo 2, immagine 1 di 1
    • Lift the keyboard toward you starting from the edge closest to the screen.
    • This ribbon still connects the taptor to the keyboard.
    • Gently place the keyboard on top of the track pad with the keys upside down.
  3. Toshiba Portege M400 Keyboard Replacement: passo 3, immagine 1 di 3 Toshiba Portege M400 Keyboard Replacement: passo 3, immagine 2 di 3 Toshiba Portege M400 Keyboard Replacement: passo 3, immagine 3 di 3
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Remove the screw on the metal plate that keeps the ribbon from sliding out.
    • Gently remove the metal plate and set it aside.
  4. Toshiba Portege M400 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Portege M400 Keyboard Replacement: passo 4, immagine 2 di 2
    • Dislodge the white ribbon connector from the two clips holding it in place using the plastic opening tools.
    • Pull out the white ribbon connector with your fingers.
Conclusione
Cal Poly, Team 4-17, Maness Spring 2013 Membro di Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,092
