Salta al contenuto principale
Toshiba Portege 3110CT Keyboard Replacement
Spencer Gamble
Spencer Gamble e un altro collaboratore
Ultimo aggiornamento il March 25, 2023
Nessuna stima
Moderato
Foto Azione
Dettagli Mancanti
Introduzione
Vai al passo 1
Keybaord replacement for this laptop is simple and only requires a screwdriver and a plastic opening tool.
Cosa ti serve
Strumenti
  1. Toshiba Portege 3110CT Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Begin by removing the battery and flipping the laptop over to see the screws
    • Using a phillips head screwdriver to remove the screws that secure the back
  2. Toshiba Portege 3110CT Keyboard Replacement: passo 2, immagine 1 di 1
    • Flip the laptop back over and open it up carefully
    • Lift up the bottom panel where the mouse click buttons are
    • Lift up slowly as simply flip it up and rest it on the keyboard as not to damage the ribbon cable connecting it
    • Using the spudger disconnect the ribbon cable connected to the bottom of the panel
  3. Toshiba Portege 3110CT Keyboard Replacement: passo 3, immagine 1 di 1
    • Using the same size phillips as before remove the two screws that hold the keyboard in place
    • Lift the keyboard up and slide it downwards and out.
Conclusione
UMass Dartmouth, Team 6-4, Martin Fall 2016 Membro di UMass Dartmouth, Team 6-4, Martin Fall 2016
UMASSD-MARTIN-F16S6G4
3 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 18
Tutti i Tempi: 388
