Salta al contenuto principale
Toshiba Portege 3110CT Fan Replacement
Spencer Gamble
Spencer Gamble e 2 altri collaboratori
Ultimo aggiornamento il January 17, 2025
Nessuna stima
Moderato
Vigilanza sulla Grammatica
Foto Azione
Introduzione Migliore
Dettagli Mancanti
Introduzione
Vai al passo 1
Fan replacement for this laptop is simple and only requires a screwdriver and a plastic opening tool.
Cosa ti serve
Strumenti
  1. Toshiba Portege 3110CT Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Begin by removing the battery and flipping the laptop over to see the screws
    • Using a phillips head screwdriver to remove the screws that secure the back
  2. Toshiba Portege 3110CT Fan Replacement: passo 2, immagine 1 di 1
    • Flip the laptop back over and open it up carefully
    • Lift up the bottom panel where the mouse click buttons are
    • Lift up slowly as simply flip it up and rest it on the keyboard as not to damage the ribbon cable connecting it
    • Using the spudger disconnect the ribbon cable connected to the bottom of the panel
  3. Toshiba Portege 3110CT Fan Replacement: passo 3, immagine 1 di 1
    • Using the same size phillips as before remove the two screws that hold the keyboard in place
    • Then simply lift the keyboard up and slide it down and out
  4. Toshiba Portege 3110CT Fan Replacement: passo 4, immagine 1 di 1
    • Remove this final screw and lift out the fan
Conclusione
UMass Dartmouth, Team 6-4, Martin Fall 2016 Membro di UMass Dartmouth, Team 6-4, Martin Fall 2016
UMASSD-MARTIN-F16S6G4
3 Membri
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 358
