Salta al contenuto principale
Toshiba NB305 Keyboard  Replacement
Nuri Chung
Nuri Chung e 3 altri collaboratori
Ultimo aggiornamento il February 25, 2023
10 - 20 minuti
Moderato
Introduzione
Vai al passo 1
When replacing your keyboard make sure that you are not to rough with the removal of the keyboard. Take your time and go slowly or you will run the risk of damaging the laptop. Replacing your keyboard can help with efficiency and make working on your leptop more productive.
Cosa ti serve
Strumenti
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Toshiba NB305 Keyboard  Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Keyboard  Replacement: passo 2, immagine 1 di 1
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Keyboard  Replacement: passo 3, immagine 1 di 2 Toshiba NB305 Keyboard  Replacement: passo 3, immagine 2 di 2
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Keyboard  Replacement, Keyboard: passo 4, immagine 1 di 2 Toshiba NB305 Keyboard  Replacement, Keyboard: passo 4, immagine 2 di 2
    • Remove the four F4 screws and the F6 screw underneath battery.
    • 4mm Phillips-0 screws.
    • 6mm Phillips-0 screws.
  5. Toshiba NB305 Keyboard  Replacement: passo 5, immagine 1 di 3 Toshiba NB305 Keyboard  Replacement: passo 5, immagine 2 di 3 Toshiba NB305 Keyboard  Replacement: passo 5, immagine 3 di 3
    • Using a spudger, gently pry out on the plastic cover.
    • Turn it over and remove plastic cover on top of laptop with power button on it.
  6. Toshiba NB305 Keyboard  Replacement: passo 6, immagine 1 di 2 Toshiba NB305 Keyboard  Replacement: passo 6, immagine 2 di 2
    • Use the plastic opening tool in little notches above the keyboard
    • Gently pry up on the keyboard until it lifts up.
    • You might hear a click when the keyboard releases.
  7. Toshiba NB305 Keyboard  Replacement: passo 7, immagine 1 di 1
    • Gently lift the keyboard up toward the screen.
    • Be careful! There is a cable still connected from the computer to the keyboard.
  8. Toshiba NB305 Keyboard  Replacement: passo 8, immagine 1 di 2 Toshiba NB305 Keyboard  Replacement: passo 8, immagine 2 di 2
    • The ribbon cable has a clip on each side holding it to the motherboard.
    • Using a spudger, press on the clips to release the cable.
    • The cable will slide out on its own when it is properly released.
Conclusione
Nuri Chung
Membro da: 10/25/16
377 Reputazione
3 Guide realizzate
USF Tampa, Team 5-5, Lacy Fall 2016 Membro di USF Tampa, Team 5-5, Lacy Fall 2016
USFT-LACY-F16S5G5
3 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 797
