Salta al contenuto principale
Toshiba NB205 N330PK Webcam Replacement
Mason McCaskill
Mason McCaskill e 7 altri collaboratori
Ultimo aggiornamento il January 21, 2025
30 minuti
Moderato
Introduzione Migliore
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Toshiba NB205 N330PK Webcam Replacement, Webcam: passo 1, immagine 1 di 2 Toshiba NB205 N330PK Webcam Replacement, Webcam: passo 1, immagine 2 di 2
    • Use a spudger to remove the small rubber screw coverings above each retaining screw.
    • Use the bit driver with a Phillips #0 bit to remove the two 5 mm screws securing the screen bezel.
  2. Toshiba NB205 N330PK Webcam Replacement: passo 2, immagine 1 di 3 Toshiba NB205 N330PK Webcam Replacement: passo 2, immagine 2 di 3 Toshiba NB205 N330PK Webcam Replacement: passo 2, immagine 3 di 3
    • Using a spudger, gently pry the screen bezel to the condition of the photograph.
    • For this procedure, it is not necessary to completely removal screen bezel so in order to reduce work, bezel is just partially removed.
  3. Toshiba NB205 N330PK Webcam Replacement: passo 3, immagine 1 di 2 Toshiba NB205 N330PK Webcam Replacement: passo 3, immagine 2 di 2
    • Use tweezers to gently remove the connector to the webcam by pulling the plug to the right (per orientation of the photo).
    • Allow the removed wire to hang in place but make note of alignment with respect to webcam.
    • This step is performed while holding down the bezel which is only partially detached.
  4. Toshiba NB205 N330PK Webcam Replacement: passo 4, immagine 1 di 3 Toshiba NB205 N330PK Webcam Replacement: passo 4, immagine 2 di 3 Toshiba NB205 N330PK Webcam Replacement: passo 4, immagine 3 di 3
    • Use the spudger to pry each side of the webcam until it releases from its adhesive back.
  5. Toshiba NB205 N330PK Webcam Replacement: passo 5, immagine 1 di 2 Toshiba NB205 N330PK Webcam Replacement: passo 5, immagine 2 di 2
    • Position the new webcam in the old webcam's position. The webcam must be carefully aligned in order to function properly with the bezel in place. Align the hole of the webcam assembly over the cylinder of the webcam stabilizer.
    • Reconnect the electrical connection.
  6. Toshiba NB205 N330PK Webcam Replacement: passo 6, immagine 1 di 3 Toshiba NB205 N330PK Webcam Replacement: passo 6, immagine 2 di 3 Toshiba NB205 N330PK Webcam Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Gently press the front bezel back into its original position.
    • Using the bit driver and Phillips #0 bit, drive the two bezel retaining screws in to place.
    • Cover the screws with the small covers with tweezers.
Linea Traguardo
Mason McCaskill
Membro da: 10/18/13
1.021 Reputazione
9 Guide realizzate
Clemson, Team 14-2, Benson Fall 2013 Membro di Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Membri
27 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 597
