Toshiba Mini NB505 Battery Replacement
Introduzione
Vai al passo 1Over time the battery will begin to not hold a charge as long as it use to or even at all. If you need to constantly have your laptop plugged in or it will not turn on, then the battery might need to be replaced. This guide will help you do just that!
Located on the bottom of the laptop, find the two tabs shown in the picture and push both of them outwards away from the battery.
Altre 4 persone hanno completato questa guida.
2Commenti sulla guida
Hello!
I need to buy a battery for this computer. How do I do please?
Tks
Beto
Battery reset power doesn't work it came on then went out
