Salta al contenuto principale
Toshiba Dynabook AX 53D Memory Replacement
Christopher
Christopher e 2 altri collaboratori
Ultimo aggiornamento il March 25, 2023
5 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show users how to replace the memory (RAM) from the Toshiba Dynabook.
Cosa ti serve
  1. Toshiba Dynabook AX 53D Memory Replacement, Battery: passo 1, immagine 1 di 1
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Memory Replacement: passo 2, immagine 1 di 1
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Memory Replacement, Memory: passo 3, immagine 1 di 1
    • Remove the 4.5 mm screw labeled 4 and lift up panel from the vented 2" x "4 memory cover in the middle of the computer.
  4. Toshiba Dynabook AX 53D Memory Replacement: passo 4, immagine 1 di 1
    • Gently pull apart the two metal support clips on either side of the chip to release from the socket. It will spring upwards when it is properly released.
  5. Toshiba Dynabook AX 53D Memory Replacement: passo 5, immagine 1 di 1
    • Gently pull the chip out of the clips.
    • Touching the contacts or the chips on the board could destroy the components.
Conclusione
Christopher
Membro da: 03/20/17
525 Reputazione
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 398
