Introduzione
Before you begin to replace the screen of your Tagital T7X be sure to review the troubleshooting page to ensure that this is a valid solution. The screen will need to be replaced if the touch screen is not responsive or does not display anything. Some soldering is required. Good luck!
Cosa ti serve
Place the Tagital T7X on a sturdy surface.
Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
Remove the ribbon cable on the top left corner of the mother board.
Gently lift the black tape up to see the ribbon cable socket.
Use a spudger to hold the cameras in place.
Gently pull the black tape away using your finger.
Next we will disconnect the digitizer ribbon cable from the motherboard.
Using the black spudger, gently push the tabs on each side of the socket to free the ribbon cable.
Insert a plastic opening tool where the screen connects with the front face of the case.
Altre 2 persone hanno completato questa guida.
