Salta al contenuto principale
Table Fan Blades Replacement
Cora Diehl
Cora Diehl e un altro collaboratore
Ultimo aggiornamento il June 11, 2021
10 minuti
Moderato
Introduzione
Vai al passo 1
If your 6-8 inch Personal Table Fan has been lagging or the blades have broke. Use this guide to replace the blades in your fan.
Before using this guide, make sure your fan works when plugged in. If it does not, the blades are not the issue, the motor is and this guide will not fix the issue.
Before beginning, make sure to unplug your fan.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Table Fan Blades Replacement, Blades: passo 1, immagine 1 di 3 Table Fan Blades Replacement, Blades: passo 1, immagine 2 di 3 Table Fan Blades Replacement, Blades: passo 1, immagine 3 di 3
    • Use a prying tool to loosen the front cover.
    • After it is pried loose, remove the cover.
  2. Table Fan Blades Replacement: passo 2, immagine 1 di 1
    • Remove two 12.7 mm Phillips #2 screws from the back cover.
    • Take off the back cover.
  3. Table Fan Blades Replacement: passo 3, immagine 1 di 1
    • Remove two 38.1 mm Phillips #2 screws from the motor.
  4. Table Fan Blades Replacement: passo 4, immagine 1 di 3 Table Fan Blades Replacement: passo 4, immagine 2 di 3 Table Fan Blades Replacement: passo 4, immagine 3 di 3
    • While holding the back of the fan, pull the blades.
    • Take off the old blades and put them aside.
  5. Table Fan Blades Replacement: passo 5, immagine 1 di 1
    • Take the motor out.
  6. Table Fan Blades Replacement: passo 6, immagine 1 di 2 Table Fan Blades Replacement: passo 6, immagine 2 di 2
    • Clean all parts of the fan.
  7. Table Fan Blades Replacement: passo 7, immagine 1 di 2 Table Fan Blades Replacement: passo 7, immagine 2 di 2
    • Put the motor and back cover back on.
    • This can be done by following steps 2, 3, and 5 in reverse.
  8. Table Fan Blades Replacement: passo 8, immagine 1 di 1
    • Place the new blade onto the metal rod on the front of the fan.
    • Push the blades onto the rod so that it is sturdy.
    • Replace the front cover.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,054
