Salta al contenuto principale
TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement
John Tangney
John Tangney e 5 altri collaboratori
Ultimo aggiornamento il January 8, 2023
10 minuti
Facile
Introduzione
Vai al passo 1
This guide will walk you through the necessary steps for replacing the cooling fan in your Toshiba Satelite E45W-C4200X.
The cooling fan is a vital piece of hardware that prevents the computer from overheating and damaging the motherboard.
Before using this guide, make sure to review the troubleshooting page to ensure the fan will need to be replaced.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: passo 1, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: passo 1, immagine 2 di 2
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 2, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 2, immagine 2 di 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 3, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 4, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 4, immagine 2 di 2
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 5, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 5, immagine 2 di 2
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 6, immagine 1 di 3 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 6, immagine 2 di 3 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: passo 6, immagine 3 di 3
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
Conclusione
Consider purchasing the entire H000085330 Toshiba Thermal Assembly E45DW-C4210. This includes the fan and heat transfer components assembled. As of January 2022, it is $14.00 on e-bay. This makes replacement much easier.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 376
