TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement
Introduzione
Vai al passo 1This guide will walk you through the necessary steps for replacing the cooling fan in your Toshiba Satelite E45W-C4200X.
The cooling fan is a vital piece of hardware that prevents the computer from overheating and damaging the motherboard.
Before using this guide, make sure to review the troubleshooting page to ensure the fan will need to be replaced.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
Consider purchasing the entire H000085330 Toshiba Thermal Assembly E45DW-C4210. This includes the fan and heat transfer components assembled. As of January 2022, it is $14.00 on e-bay. This makes replacement much easier.
Altre 2 persone hanno completato questa guida.
