Salta al contenuto principale
TCA PRC 152A Disassembly
Tomazo_88
Tomazo_88 e un altro collaboratore
Ultimo aggiornamento il April 2, 2021
25 - 45 minuti
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This tutorial will explain how to completely disassemble the TCA PRC 152A radio and accessories.
Disclaimer : Disconnect all peripherals before disassembling.
Cosa ti serve
Strumenti
Mostra di più…
  1. TCA PRC 152A Disassembly, Prepare the radio for dissasembly: passo 1, immagine 1 di 1
    • Remove antenna and battery before dissasembly
    • Prepare the tools before starting We'll start with the radio and then the accessories...
  2. TCA PRC 152A Disassembly, Removing the backpannel: passo 2, immagine 1 di 3 TCA PRC 152A Disassembly, Removing the backpannel: passo 2, immagine 2 di 3 TCA PRC 152A Disassembly, Removing the backpannel: passo 2, immagine 3 di 3
    • Remove 4 screws on the backpannel
    • Phillips PH3
    • The small retention piece is held by the screw. Be careful not to lose the spring
  3. TCA PRC 152A Disassembly, Removing the backpanel: passo 3, immagine 1 di 2 TCA PRC 152A Disassembly, Removing the backpanel: passo 3, immagine 2 di 2
    • Carefully open the rear panel with the opener's plastic tool.
    • You can see the connection map of the different terminals.
    • GPS option (Does not work)
    • PTT and config button socket
    • U283 6PIN connector
    • ON/OFF/Volume knob
    • Side connector (Does not work)
  4. TCA PRC 152A Disassembly, Removing frontpannel: passo 4, immagine 1 di 3 TCA PRC 152A Disassembly, Removing frontpannel: passo 4, immagine 2 di 3 TCA PRC 152A Disassembly, Removing frontpannel: passo 4, immagine 3 di 3
    • Carefully open the front panel with the opener's plastic tool.
    • Microphone attached to the PCB board (1.080KOhm).Can be replaced by POW-2744P-B-R
    • Speaker FCE 16Ohm 1Watt.
    • Beware of silicone for the sealing of the elements.
  5. TCA PRC 152A Disassembly, Frontpannel microphone removal: passo 5, immagine 1 di 3 TCA PRC 152A Disassembly, Frontpannel microphone removal: passo 5, immagine 2 di 3 TCA PRC 152A Disassembly, Frontpannel microphone removal: passo 5, immagine 3 di 3
    • Remove 1 screw
    • Phillips PH1
    • Carefully remove withe the plastic tool
  6. TCA PRC 152A Disassembly, Display and keyboard front card: passo 6, immagine 1 di 3 TCA PRC 152A Disassembly, Display and keyboard front card: passo 6, immagine 2 di 3 TCA PRC 152A Disassembly, Display and keyboard front card: passo 6, immagine 3 di 3
    • Remove 4 screws
    • Phillips PH2
    • Disconnect the flat connector
    • Use caution when you remove the flat connector
  7. TCA PRC 152A Disassembly, Display and keyboard front card: passo 7, immagine 1 di 2 TCA PRC 152A Disassembly, Display and keyboard front card: passo 7, immagine 2 di 2
    • Place the electronics elements on ESD bags
  8. TCA PRC 152A Disassembly, Peripheral back card: passo 8, immagine 1 di 3 TCA PRC 152A Disassembly, Peripheral back card: passo 8, immagine 2 di 3 TCA PRC 152A Disassembly, Peripheral back card: passo 8, immagine 3 di 3
    • Disconnect 2 JSP connectors and 2 flat connector
    • Remove 4 screws
    • Phillips PH2
    • Carefully disconect the connectors and the board
  9. TCA PRC 152A Disassembly, Mainboard removal: passo 9, immagine 1 di 3 TCA PRC 152A Disassembly, Mainboard removal: passo 9, immagine 2 di 3 TCA PRC 152A Disassembly, Mainboard removal: passo 9, immagine 3 di 3
    • Remove 4 screws
    • Phillips PH2
    • Disconnect the antenna connector
    • Carefully removing the mainboard
    • Thermal paste between the card and the body
  10. TCA PRC 152A Disassembly, Side connectors removal: passo 10, immagine 1 di 2 TCA PRC 152A Disassembly, Side connectors removal: passo 10, immagine 2 di 2
    • Remove 2 screws
    • Phillips PH1
    • Carefully removing the connector
  11. TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 11, immagine 1 di 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 11, immagine 2 di 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 11, immagine 3 di 3
    • Remove 2 screws
    • Phillips PH3
    • Remove the topcover, take care about short circuit
  12. TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 12, immagine 1 di 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 12, immagine 2 di 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: passo 12, immagine 3 di 3
    • Remove battery stick (18650 Panasonic)
    • Remove 2 screws
    • Phillips PH3
    • Take off the inner white retainer
Linea Traguardo
Tomazo_88
Membro da: 06/09/20
379 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 100
Tutti i Tempi: 3,663
