Suzuki DR650 SE membrane and seal replacement
Introduzione
Vai al passo 1At Unterdruckbenzinhähne it can always lead to problems with the gasoline supply and leaks. That's why it should be checked and cleaned again and again. Here's a guide to the complete seal replacement on a Suzuki DR650SE SP46B. Please use original parts. (Already had problems with accessories)
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
The two screws, here quite funny with a large Phillips, or a 10-fork or ring spanner, unscrew.
Very important: The tank should be at most 1/4 full so that it does not leak. Then you can put it upright.
Re-screw the 5 Phillips screws with a suitable Phillips screwdriver (PH2).
gasoline connection
Vacuum port
For functional testing, you must now apply a slight vacuum to the vacuum connection, which causes the cap to open. This can then be tested by blowing at the gasoline connection. When the vacuum drops, the shutter must close immediately.
Now install the foot gasket.
Un ringraziamento speciale a questi traduttori:
100%
irlanda ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
