Salta al contenuto principale
Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement
Luke Johnson
Luke Johnson e 3 altri collaboratori
Ultimo aggiornamento il December 28, 2023
20 minuti
Moderato
Introduzione
Vai al passo 1
This guide will teach you how to remove the main body panel to the underwater scooter.
  1. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement, Top Floater Removal: passo 1, immagine 1 di 1
    • Remove the black screw by rotating it counterclockwise.
  2. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: passo 2, immagine 1 di 1
    • Hold the device in place and pull up on the floater.
  3. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: passo 3, immagine 1 di 1
    • Remove the top floater.
  4. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement, Battery: passo 4, immagine 1 di 1
    • Turn the device upside-down.
  5. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: passo 5, immagine 1 di 1
    • Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
  6. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: passo 6, immagine 1 di 1
    • A push tab holds the battery in.
  7. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: passo 7, immagine 1 di 1
    • Push the tab in and pull the battery outward to remove it.
  8. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement, Lower Panel: passo 8, immagine 1 di 1
    • Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
  9. Sublue WhiteShark Mix Underwater Scooter Lower Panel Replacement: passo 9, immagine 1 di 1
    • Pull the panel forward.
    • You may need to use pry tools to aid in separating the panels.
Conclusione
Luke Johnson
Membro da: 11/01/23
391 Reputazione
4 Guide realizzate
Un commento
Is it possible to replace the electronics of the Sublue Watershark Mix?
Alenka Arambašić - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 134
