Salta al contenuto principale
Straight Leg Canopy Tent Arm  Replacement
Virginia Gonzalez
Virginia Gonzalez e 2 altri collaboratori
Ultimo aggiornamento il June 23, 2017
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
This guide will demonstrate how to remove and replace a broken or bent arm of a Straight Leg Canopy Tent. There are 16 individual arms that allow for the tent to fully extend and open. Prior-knowledge skills useful to complete this task would be how to properly use a Phillips screwdriver and a wrench. Before starting this fix, the canopy cover should be removed for easy access of the joints and the tent should be standing and opened.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Straight Leg Canopy Tent Arm  Replacement, The Tent Arm: passo 1, immagine 1 di 2 Straight Leg Canopy Tent Arm  Replacement, The Tent Arm: passo 1, immagine 2 di 2
    • Steps 1 through 3 are for removal of the broken arm.
    • At the top joint, there will be a nut in the back that is holding the screw in place.
    • Use the wrench to hold the nut in place.
    • Use the Phillips screwdriver to unscrew the screw.
  2. Straight Leg Canopy Tent Arm  Replacement: passo 2, immagine 1 di 3 Straight Leg Canopy Tent Arm  Replacement: passo 2, immagine 2 di 3 Straight Leg Canopy Tent Arm  Replacement: passo 2, immagine 3 di 3
    • Repeat step 1 for the other two joints.
    • There is no need to hold the nut with the wrench for the middle joint because this joint holds two arms together.
    • The nut is in the middle of the two arms, so once you have loosened the screw, the black connector will come off.
    • Hold the nut in place and finish unscrewing the screw.
  3. Straight Leg Canopy Tent Arm  Replacement: passo 3, immagine 1 di 1
    • Remove the arm(s), after all three joints are unscrewed.
  4. Straight Leg Canopy Tent Arm  Replacement: passo 4, immagine 1 di 1
    • Steps 4 through 7 are for arm replacement.
    • Replace the new arm, starting at the top joint again.
    • Place the screw through the hole and twist the nut on the backside of the screw.
    • Hold the nut with the wrench while you screw the screw to make it tight.
  5. Straight Leg Canopy Tent Arm  Replacement: passo 5, immagine 1 di 2 Straight Leg Canopy Tent Arm  Replacement: passo 5, immagine 2 di 2
    • At the middle joint, place the screw through the hole in the black plastic connector and through the conjoining arms.
    • Use the Phillips screwdriver to tighten the screw in place.
  6. Straight Leg Canopy Tent Arm  Replacement: passo 6, immagine 1 di 1
    • Repeat step 4 for the bottom joint.
    • Remember to use the wrench to hold the nut in place while you screw the screw back tightly.
  7. Straight Leg Canopy Tent Arm  Replacement: passo 7, immagine 1 di 2 Straight Leg Canopy Tent Arm  Replacement: passo 7, immagine 2 di 2
    • Replace the canopy top by attaching the Velcro pieces.
    • Once all of the joints have been tightly screwed back in place, the tent should be ready to reuse again.
Conclusione
After following these instructions in chronological order, the end result would be for the successful removal and replacement of an arm on a Straight Leg Canopy Tent.
1Commento della guida
where do you buy the leg from?
MK604CB - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,602
