Introduzione
Use this guide to replace the cooling fan in your Steam Deck LCD, or remove it for cleaning.
Remember: follow general electrostatic discharge (ESD) safety procedures while repairing your device.
Note: Valve started shipping Steam Decks with refreshed internal designs in early 2023. Your Steam Deck may look different than the one depicted in the photos, but the procedure is the same. The Steam Deck's fan design differs between versions. Before ordering a replacement fan, remove the back cover of your Steam Deck to check what version you have. An original Steam Deck will have a metallic motherboard shield and a fan with square sides, as seen here. A refreshed Steam Deck will have a black motherboard shield and a fan with curved sides, as seen here.
Cosa ti serve
Power down your Steam Deck and unplug any cables.
Attrezzo utilizzato in questo passaggio:FixMat$36.95
Use a Phillips driver to remove the eight screws securing the back cover:
Four coarse thread 9.5 mm-long screws
Four fine thread 5.8 mm-long screws
Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
Pry up on the back cover to release it from the locking clips.
Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
Remove the back cover.
Use a Phillips driver to remove the three screws securing the board shield:
One 3.4 mm screw
Two 3.7 mm screws
Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
Use a Phillips driver to remove the two 3.7 mm screws securing the fan.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Altre 78 persone hanno completato questa guida.
22 Commenti
Hi ifixit Team, as the cooler seems to be a non factory one: how does it compare noise wise to the standard Steam Deck cooler, which is unbearably loud?
To those asking, you want a huaying fan as opposed to a delta fan. The delta is terribly bad with its acoustics.
is this the delta or huaying?
