Salta al contenuto principale
Stapler Maintenance
Stapler Maintenance
Sequoia Equities
Sequoia Equities e 5 altri collaboratori
Ultimo aggiornamento il August 30, 2024
20 secondi - 1 minuto
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Use this guide to refill and empty stapler, so you can get back to those TPS reports.
  1. Stapler Maintenance, Open & Identify: passo 1, immagine 1 di 2 Stapler Maintenance, Open & Identify: passo 1, immagine 2 di 2
    • Be careful while handling staples or any sharp object in general.
    • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
    • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
  2. Stapler Maintenance, Insert Staples: passo 2, immagine 1 di 2 Stapler Maintenance, Insert Staples: passo 2, immagine 2 di 2
    • Get a cluster of staples and carefully place it in the carrier.
    • Make sure there is enough room for the pusher to contact the staples.
    • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
  3. Stapler Maintenance: passo 3, immagine 1 di 1
    • Don’t staple your hand, or anyone else for that matter.
    • Congratulations! You have successfully replaced staples in your stapler.
Conclusione
Altre 7 persone hanno completato questa guida.
2Commenti sulla guida
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - Replica
@ cookie clicker When I attempted to load the staples, the spring became detached. However, I'm unsure where to reattach it, and I now have a loose, short plastic rod.
Nadia Eira - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 58
Ultimi 7 Giorni: 288
Ultimi 30 Giorni: 1,335
Tutti i Tempi: 28,090
