Salta al contenuto principale
Standard 1 Flexi Dog Leash Cord Replacement
Lisa Samy
Lisa Samy e 4 altri collaboratori
Ultimo aggiornamento il May 23, 2024
30 minuti
Moderato
Introduzione
Vai al passo 1
Dog leashes are typically thrown away once parts such as the cord are worn out after extended use. However, it is possible to replace the cord instead of throwing the entire leash away. This guide illustrates how to replace the cord of a Standard 1 Flexi Dog Leash. Since guides to replace the cord of a dog leash are scarce, this repair is helpful to explain this rather unknown procedure.
Note: This fix is meant for dog leashes catered towards smaller to medium sized dogs (less than 46 Ibs).
  1. Standard 1 Flexi Dog Leash Cord Replacement, Standard 1 Flexi Dog Leash Cord Replacement: passo 1, immagine 1 di 3 Standard 1 Flexi Dog Leash Cord Replacement, Standard 1 Flexi Dog Leash Cord Replacement: passo 1, immagine 2 di 3 Standard 1 Flexi Dog Leash Cord Replacement, Standard 1 Flexi Dog Leash Cord Replacement: passo 1, immagine 3 di 3
    • Starting at the lower side of the handle, pry open the leash handle with a metal spudger.
  2. Standard 1 Flexi Dog Leash Cord Replacement: passo 2, immagine 1 di 3 Standard 1 Flexi Dog Leash Cord Replacement: passo 2, immagine 2 di 3 Standard 1 Flexi Dog Leash Cord Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Halberd Spudger
    $2.99
    • Use a halberd spudger to guide the metal coil out while removing the spool.
    • Twist the spool out.
    • Be careful not to warp the metal tension spool while removing the plastic assembly.
  3. Standard 1 Flexi Dog Leash Cord Replacement: passo 3, immagine 1 di 3 Standard 1 Flexi Dog Leash Cord Replacement: passo 3, immagine 2 di 3 Standard 1 Flexi Dog Leash Cord Replacement: passo 3, immagine 3 di 3
    • Unwind the damaged leash cord.
    • Keep the cord steady and carefully wrap it around the spool.
  4. Standard 1 Flexi Dog Leash Cord Replacement: passo 4, immagine 1 di 3 Standard 1 Flexi Dog Leash Cord Replacement: passo 4, immagine 2 di 3 Standard 1 Flexi Dog Leash Cord Replacement: passo 4, immagine 3 di 3
    • Cut the tied end of the damaged leash cord with scissors, or simply untie and remove it.
  5. Standard 1 Flexi Dog Leash Cord Replacement: passo 5, immagine 1 di 3 Standard 1 Flexi Dog Leash Cord Replacement: passo 5, immagine 2 di 3 Standard 1 Flexi Dog Leash Cord Replacement: passo 5, immagine 3 di 3
    • Insert the new leash cord into the holes and tie the end off with a secure knot.
    • The cotton twine cordage in the guide is for demonstration purposes only and is not strong enough for a dog leash.
  6. Standard 1 Flexi Dog Leash Cord Replacement: passo 6, immagine 1 di 3 Standard 1 Flexi Dog Leash Cord Replacement: passo 6, immagine 2 di 3 Standard 1 Flexi Dog Leash Cord Replacement: passo 6, immagine 3 di 3
    • Wind the new leash cord around the spool.
  7. Standard 1 Flexi Dog Leash Cord Replacement: passo 7, immagine 1 di 2 Standard 1 Flexi Dog Leash Cord Replacement: passo 7, immagine 2 di 2
    • Align the metal coil end with the peg's groove.
    • Keep the metal coil wrapped around the peg tightly.
    • Fit the coiled peg back into the spool.
  8. Standard 1 Flexi Dog Leash Cord Replacement: passo 8, immagine 1 di 1
    • Insert new leash cord into and out of exit hole.
    • Make sure the measurement of the new leash cord is the same as the old one.
  9. Standard 1 Flexi Dog Leash Cord Replacement: passo 9, immagine 1 di 2 Standard 1 Flexi Dog Leash Cord Replacement: passo 9, immagine 2 di 2
    • Insert the new leash cord through the rubber O-ring.
  10. Standard 1 Flexi Dog Leash Cord Replacement: passo 10, immagine 1 di 2 Standard 1 Flexi Dog Leash Cord Replacement: passo 10, immagine 2 di 2
    • Tie the new leash cord onto the keychain hook with a secure knot.
  11. Standard 1 Flexi Dog Leash Cord Replacement: passo 11, immagine 1 di 2 Standard 1 Flexi Dog Leash Cord Replacement: passo 11, immagine 2 di 2
    • Reattach the dog leash handle to its other half.
    • When you hear a "click" or "snap," it means the leash is fully intact.
Conclusione
If the leash repeatedly gets jammed, the new cord getting tangled up inside is the most likely cause. It is best to reopen the leash and untangle the cord, before considering whether a cord different from the guide would suit your leash better.
Altre 2 persone hanno completato questa guida.
Lisa Samy
Membro da: 09/21/22
232 Reputazione
1 Guida realizzata
CSU Fullerton, Team 1-1, Bruce Fall 2022 Membro di CSU Fullerton, Team 1-1, Bruce Fall 2022
CSUF-BRUCE-F22S1G1
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 72
Tutti i Tempi: 2,813
