Salta al contenuto principale
Spy Net Ultra Vision Goggles Microphone Replacement
Cosa ti serve
  1. Spy Net Ultra Vision Goggles Microphone Replacement, Open the Device: passo 1, immagine 1 di 1
    • Using the screwdriver, remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pull apart the back of the device, using the plastic opening tool if needed. To do this, locate the groves running along the side of the entire device and wedge it open.
    Chiedi a FixBot
    Aggiungi Commento
  2. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Wiring from the Circuit Board: passo 2, immagine 1 di 1
    • Find the connection of the red and black wires to the circuit board behind the LED screen.
    • Un-solder the wires from the board using the soldering iron.
    • Need Help Soldering? Check out Come saldare e dissaldare componenti elettrici
    Chiedi a FixBot
    Aggiungi Commento
  3. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Microphone: passo 3, immagine 1 di 1
    • Find the connection of the red and black wires to the funnel-shaped lens cover.
    • Un-solder the wires from the microphone using the soldering iron.
    • Remove the red and black wires from the device and solder on the replacement.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Justin Diehl
Membro da: 09/22/14
66 Reputazione
Una guida realizzata
USF Tampa, Team 4-5, Brown Fall 2014 Membro di USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 27
Tutti i Tempi: 650
