Salta al contenuto principale
Sostituzione batteria MacBook Air 11" Mid 2012
Cosa ti serve
  1. Sostituzione batteria MacBook Air 11" Mid 2012, Scocca inferiore: passo 1, immagine 1 di 1
    • Spegni e chiudi il tuo portatile. Appoggialo su una superfice morbida a testa in giù.
    • Svita le seguenti dieci viti:
    • Due viti Pentalobe 5-Point da 8 mm
    • Otto viti Pentalobe 5-Point da 2,5 mm
    • Puoi trovare il cacciavite speciale per rimuovere le viti Pentalobe 5-Point qui.
    When you say:
    Remove the following ten screws:
    Two 8 mm 5-point Pentalobe screws
    Eight 2.5 mm 5-point Pentalobe screws
    Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
    Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
    Nerdily yours,
    Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
    larryleveen - Replica
    The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
    Michael Welham -
    I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
    Allen - Replica
    The magnetic mat is
    GERARD SZAREK -
    Keep the 2.5mm tiny screws away from the MagSafe connector as they will be attracted and sucked in to the magnet.
    Frank O'Carroll - Replica
    A tip an old bench tech taught me that has saved me many times: I put clear “Scotch” tape over the case screws as they became “free”. The tape kept them in place while I lifted the lid off, cleaned it etc.
    Michael Mee - Replica
    Thank you for a really smart tip! I will be using that countless more times!
    Lilljedahl -
    I’m confused about internet recovery and installing MacOS. Is all of this done before placing in the new ssd card or after. I don’t have any files that I would like to safe/transfer, is all of this necessary, if I don’t do it before placing new ssd, will I still be able to instal/upgrade macOS afterwards.
    It’s an old Mac and now it won’t start or charge, I know I will have to replace battery and put new battery first and turn on Mac before doing the ssd stuff. Since it won’t effing start.
    I’m really clueless about backing up old ssd, since I don’t need any files, besides MacOS(software) ,and is that related to the ssd?
    AMG - Replica
    The answer to your question: You need to insert your SSD into the computer before internet recovery. If you start the recovery before inserting SSD, it won’t affect the setup, you won’t damage anything. But your SSD will not be detected (as there isn’t one inserted.)
    Also, a little tip: If you bought a used SSD, go into Disk Utility and format the drive with the highest security level to permanently remove all of the previous files.
    Also a FYI: Internet Recovery will load up Mac OS X 10.9.5 Mavericks, so I would recommend making a recovery drive from a Big Sur (or desired version) through another Mac, and a USB. You can visit this support doc: https://support.apple.com/en-us/HT201372
    Hope this helps! -Dan
    danielwen -
    I got a macbook air with a damaged and swollen battery. I could remove all screws, except one 2,5 mm screw. I’m afraid it got damaged while attempting to remove it, I have no grip with the P5 pentalobe screwdriver. How can I proceed?
    Robert Hermans - Replica
    Hi Robert!
    Try some techniques found in this stripped screw removal guide. Good luck!
    Arthur Shi -
    Hello I have a macbook air they are say they do not have parts for my laptop macbook air 11 inches 2013 mid need to replace battery which one to buy
    vensilver - Replica
    Hello! This is the part you want—maybe we’re not able to ship it to you if you’re out of the United States. The battery in your MacBook Air should be the same for all 11” between mid-2011 to early-2015.
    Arthur Shi -
    The smaller screws went in more easily when I put back all the screws along the hinge edge first.
    Rachel Slatkin - Replica
  2. Sostituzione batteria MacBook Air 11" Mid 2012: passo 2, immagine 1 di 1
    • Infila le dita tra lo schermo e la scocca inferiore e tira verso l'alto per liberare la scocca dal MacBook Air.
    My replacement battery (bought from Fixje in the Netherlands) had a rather thick rubber plate glued onto the top of the battery connector, which made it difficult to reattach the back cover. Specifically, the clip in the middle of the back cover could not reach into the slot.
    The rubber plate could be removed which made the back close (and also made it look like the battery connector of the original battery), but the middle clip would nevertheless not attach with a clicking sound. Still, the back covers attached tightly and does not flex when pressed in the middle.
    It's possible that that specific replacement battery is a hair of a millimetre thicker than the original battery which prevents the middle clip to reach into the slot fully.
    Philip Dygeus - Replica
  3. Sostituzione batteria MacBook Air 11" Mid 2012, Batteria: passo 3, immagine 1 di 2 Sostituzione batteria MacBook Air 11" Mid 2012, Batteria: passo 3, immagine 2 di 2
    • Usa la parte piatta di uno spudger per fare leva su entrambi i lati del connettore della batteria per sollevarlo e scollegarlo dalla sua presa sulla scheda madre.
    • Piega leggermente il cavo della batteria in modo che il connettore non faccia accidentalmente contatto con la presa.
    I performed this on my MacBook Air (11-inch, Mid 2011), model A1370. Rather than using the spudger to un-attach the batter connector, I gripped either side with my fingers as the second photographs indicated, and gently pry/wiggled it up and out by initially pinching into the side gap with my finger nails. The reason I did it this way is that the spudger works by leverage and I was afraid to rest it against the components surrounding the connector. The photos and instructions are excellent and illustrate the maneuver perfectly.
    Allen - Replica
    Hello there... In my case by battery exploded.... Can I still try to change it using these instructions?
    Fabio Matos - Replica
    The instruction to lift the edges of battery connector before disconnecting is certainly not clear. In my case, the cconnector pins came off the board with the battery, requiring further costly repairs. I would suggest that this instruction be more specific and include a caution.
    Deirdre Rogan - Replica
    It worked fine for me, but as others mentioned, you need to be careful to remove the battery connector from the motherboard connector and not accidentally remove the motherboard connector from the motherboard itself.
    Additionally, on reassembly, I found that quit a bit of pressure was needed to get the new battery's connector to snap in place. More than I was comfortable applying, but it was necessary and it worked without a problem.
    shamino - Replica
    I just used my finger(nails), came off easily (even though i have a full iFixIt set).
    Dennis van der Pool - Replica
  4. Sostituzione batteria MacBook Air 11" Mid 2012: passo 4, immagine 1 di 1
    • Svita le seguenti cinque viti che fissano la batteria alla scocca superiore:
    • Due viti Torx T5 da 5,2 mm
    • Una vite Torx T5 da 6 mm
    • Due viti Torx T5 da 2,6 mm
    In my case the screw points connecting the old battery the case had fractured or broken. The broken bits needed to be cleaned out of the case before installing the replacement battery. Didn't want any loose fragments rattling about inside.
    Allen - Replica
  5. Sostituzione batteria MacBook Air 11" Mid 2012: passo 5, immagine 1 di 1
    • Quando lavori con la batteria evita di schiacciare o toccare le sei celle ai polimeri di litio esposte.
    • Solleva la batteria dal suo bordo più vicino alla scheda madre e rimuovila dalla scocca superiore.
    • Se stai installando una nuova batteria dovresti calibrarla una volta rimontato il tutto:
    • Carica al 100% e lascia sotto carica per almeno altre 2 ore. Quindi scollega l'alimentatore e usa il dispositivo normalmente per scaricare la batteria. Quando vedi l'avviso di batteria quasi scarica, salva il tuo lavoro e continua ad usare il portatile finché non si spegne. Aspetta almeno 5 ore, quindi carica la batteria al 100% senza interruzioni.
    • Se riscontri dei comportamenti anomali o dei problemi dopo l'installazione, potresti dover resettare l'SMC del tuo MacBook.
    What if new battery comes with what looks like plastic around the 6 cells?
    Allison - Replica
    I'm having trouble reconnecting the pins to the new battery cable. Any suggestions?
    The cable on my new battery needed to be massaged to reconnect with the pins. Use your old battery as an example for how the cable should sit in the empty space.
    Joe Ponce - Replica
    In my case, the replacement battery cable was quite stiff. In order to properly connect it to the logic board, BEFORE screwing the battery into the board, I carefully bent the cable and I connected it to the board. AFTER connecting the cable, carefully move the part of the batter closest to the logic board into place, and take care of those screws first.
    Chris 1000 - Replica
    Followed the instructions and everything went smoothly. Less than 20 minutes later everything assembled and my MacBook Air working very well.
    Thanks
    Luis Lopes - Replica
    Two of the battery cells were “blown up” in my laptop. We simply removed it with these instructions and now it’s working again, when plugged in only, of course.
    bob - Replica
    As with Chris 1000, the replacement battery cable is stiff. First position the battery loosely into it's slot, then align the cable connector over the pins & press gently but firmly to seat the connector. Secondly, seat the battery to line up with all of it's screw fasteners for the reassembly.
    Steve G - Replica
    Instructions did not mention the plastic film on top of the battery. Similar to a peel away film on a new phone. But it had screws holes in it and does not peel away as easily as a phone Peels away from edge easily enough but had a little "pull" to it over the cells. For now I left it. Quick google searches did not clarify the issue. If anyone can confirm I should pull it off I'll open it up again and remove. The install is easy.
    Eric Strausser - Replica
    I think I saw a note that said to leave it. But side-note, i'm glad to see someone replacing the battery more recently, as I just purchased myself a new macbook but my son asked if we can replace the battery and I honestly didn't even realize that it was possible for some reason. I think for the minimal cost involved and the fact that my 2011 still works flawlessly he'll enjoy it for a few more years to come as well. I hope the new ones are made as well quality wise!!
    Teresa Powell -
Conclusione
Per rimontare il dispositivo, segui queste istruzioni in ordine inverso.
Altre 138 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Sara Balestra ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
iFixit Membro di iFixit
Staff
118 Membri
19.585 Guide realizzate
21 Commenti
I followed the directions in the reverse order, but now I have the old battery in my laptop again. Help?
Jenny Doehammer - Replica
I love you Jenny. That is all.
Darren Embry -
Great guide. Identified my parts, ordered them per the suggestions, and had the battery swapped out in 10 minutes. I like to use a magnetic sheet to hold and organize my screws for repairs like this - it keeps the proper size screws in the proper holes. If you don't have access to magnetic sheeting like I do from my graphics shop, an oval car magnet or a fridge magnet will work as well. The screwdriver recommended are of better quality than I expected. Thanks Ifixit.
rick - Replica
I want to marry Jenny
Pete - Replica
Incredibly easy - done in 15 minutes.
stilesdylan - Replica
After installing new battery Macbook air says "battery not charging" *has an X on the battery indicator*.
The MACsafe2 charger has an orange light.
The battery information indicates;
battery installed: yes
condition: Normal.
Full charge capacity: 5000 (mAh).
Charge remaining: no
Fully charged: no
Charging: no
cycle count: 0
Amperage(mA): 0
Voltage(Mv): 7500
Did a SMC reset a few time.. still no luck. please help
waseem abbas - Replica
awesome instructions…it worked! My MacBook Air 2012 now has a better battery and it was easy. Thank you
Jeffrey Louden - Replica
Please note that the screws holding the lower case on go in at a slight angle. If you don’t hold the screwdriver at this angle the tiny torx bit won’t mate properly with the head of the screw and you could damage the screw or the bit. If you don’t screw them back in at the correct angle you could have the same problem, or strip the threads on the case and/or have the screws sticking out a bit and they could snag on or scratch something. However, the instructions are correct.
rideswithscissors - Replica
A new life for my MacBook Air!
fstoer - Replica
I followed this guide and the batter connector has come loose twice now. The first time I opened the case back up and rearranged the cable before plugging it back in. This fix lasted less than 24 hours.
Does anyone have any advice for me before I go in and try again?
Sarah - Replica
thanks worked perfectly and appreciate the help!
Jim Lukens - Replica
I am now having a problem with my battery install that was very successful and working a week ago. No response yet from ifixit. I think their battery was bad or it has messed up the battery software in the macbook air. Not very happy or satisfied at this point as my mac is no longer functional the new battery battery will no longer hold charge at all. I am very sorry I disposed of the original too quickly now. 80% charge is better than none.
Was super easy to replace the battery in my MBA. It took me about 15 minutes to do it.
Christina - Replica
Thankfully Ifixit has responded and is very helpful and is issuing me a new battery to replace the one that is not working. I will get it a week or so and try again. fingers crossed.
So I ended up with another vendor battery but even it has issues. Apple Store said this age mac air is beyond the range of their diagnostic tools and its about finding a high quality battery vs anything being wrong with the mac itself software/hardware all of the presenting issues are low battery quality related. Apparently battery quality is not the best across all manufacturers. Take that for what its worth but its what I heard.
Apple store agreed even the latest MacAir is not much faster/better because processor is still very similar, Storage / RAM are the largest changes so its hard to justify new Mac cost. They actually said if I could nurse battery as is and try others if they fail is probably the best way to address. It works fine charges to 100, counts cycles, but cuts out randomly under 20%. I still get good 4 hours use which is fine for me.
Ifixit has been extremely helpful and has offered to refund me so I have been happy with Ifixit & this guide was fully correct and will continue to use ifixit.
Jim Lukens -
Installed the new battery and it will not charge. Anyone able to help?
kurtvetterling - Replica
Done in 20 minutes I’m a little slow but very easy
nelsonmartinez - Replica
Hi! I installed this battery successfully on my MBA mid 2012. It works fine but even after calibrating it properly and doing the SMC reset, I do not get longer battery life. Even though the capacity increased (4443 mAh at the moment) I get the same problem as before: at 20% remaining level battery level suddenly drops to 6% and the macbook turns off very quickly. I tried to calibrate multiple times, nothing changed.
Any ideas?
Thank you
Jukka666 - Replica
The installation worked out well. Great guide thanks
peterwordsworth - Replica
Great simple guide, seems like difficulty easy and 5-7 min max though.
Only thing easier is maybe inserting a usb into the computer?
Greg B - Replica
Super easy-For to easy!!
Moritz Ascherl - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 57
Ultimi 30 Giorni: 394
Tutti i Tempi: 82,250
