Salta al contenuto principale
Sony Vaio VPCCW17FX Speakers Replacement
Brianna Rukes
Brianna Rukes e 6 altri collaboratori
Ultimo aggiornamento il December 8, 2022
10 - 15 minuti
Moderato
Inconveniente Markup
Dettagli Mancanti
Introduzione
Vai al passo 1
In order to remove the speakers safely, be sure to take out the battery first. The speakers are located under the bottom covering of the laptop.
Cosa ti serve
Strumenti
  1. Sony Vaio VPCCW17FX Speakers Replacement, Speakers: passo 1, immagine 1 di 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Speakers Replacement: passo 2, immagine 1 di 1
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Speakers Replacement: passo 3, immagine 1 di 2 Sony Vaio VPCCW17FX Speakers Replacement: passo 3, immagine 2 di 2
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Speakers Replacement: passo 4, immagine 1 di 2 Sony Vaio VPCCW17FX Speakers Replacement: passo 4, immagine 2 di 2
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Sony Vaio VPCCW17FX Speakers Replacement: passo 5, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Sony Vaio VPCCW17FX Speakers Replacement: passo 6, immagine 1 di 1
    • Lift and remove the back cover.
  7. Sony Vaio VPCCW17FX Speakers Replacement: passo 7, immagine 1 di 2 Sony Vaio VPCCW17FX Speakers Replacement: passo 7, immagine 2 di 2
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Sony Vaio VPCCW17FX Speakers Replacement: passo 8, immagine 1 di 2 Sony Vaio VPCCW17FX Speakers Replacement: passo 8, immagine 2 di 2
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Sony Vaio VPCCW17FX Speakers Replacement: passo 9, immagine 1 di 3 Sony Vaio VPCCW17FX Speakers Replacement: passo 9, immagine 2 di 3 Sony Vaio VPCCW17FX Speakers Replacement: passo 9, immagine 3 di 3
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
Conclusione
Brianna Rukes
Membro da: 03/21/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 544
