Salta al contenuto principale
Sony Vaio VPCCW17FX Hard Drive Replacement
Tiffani Beck
Tiffani Beck e 5 altri collaboratori
Ultimo aggiornamento il December 6, 2022
5 minuti
Facile
Introduzione
Vai al passo 1
In order to remove the Hard Drive safely, be sure to take out the battery first. The Hard Drive is under a panel on the laptop and can be ejected by removing screws.
Cosa ti serve
Strumenti
  1. Sony Vaio VPCCW17FX Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Hard Drive Replacement: passo 2, immagine 1 di 1
    • Slide the two latches towards the center of the battery to release it.
  3. Sony Vaio VPCCW17FX Hard Drive Replacement: passo 3, immagine 1 di 2 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 3, immagine 2 di 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Hard Drive Replacement: passo 4, immagine 1 di 2 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 7.7 mm screws from the hard drive cover and place it to the side.
  5. Sony Vaio VPCCW17FX Hard Drive Replacement: passo 5, immagine 1 di 3 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 5, immagine 2 di 3 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 5, immagine 3 di 3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that hold the hard drive in place.
    • Use the tab to slide the hard drive away from the laptop.
    • Set the disconnected hard drive away from the laptop.
  6. Sony Vaio VPCCW17FX Hard Drive Replacement: passo 6, immagine 1 di 3 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 6, immagine 2 di 3 Sony Vaio VPCCW17FX Hard Drive Replacement: passo 6, immagine 3 di 3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that cover the hard drive.
    • Use the tab to pull up on the metal cover and remove it.
    • You are now free to replace the hard drive.
Conclusione
Tiffani Beck
Membro da: 03/20/17
219 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,753
