Sony Vaio VGN-SZ120P Logic Board Replacement
Introduzione
Vai al passo 1Use this guide to guide you in replacing your laptop's logic board (motherboard).
Hazards
Keep out of reach of children and pets.
DO NOT attempt teardown or repair you device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged and turned off before performing any maintenance on the system.
Cosa ti serve
Set the computer display-side down.
Unlock the battery by sliding the port-side latch to the 'unlock' position.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Lift the film covering to reveal the memory module with the tweezers.
Pull the tabs on both sides of the RAM away from the module. The module will pop up.
Repeat this step for the other RAM module located directly above the memory module just removed.
Turn the laptop upside down.
Remove the three screws from the front mouse panel located on the bottom of the laptop.
Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
Before proceeding, remove all black tape holding down wires and other cabling.
To remove the VGA cable, lift up on the metal bracket and gently lift the connector off the logic board.
To remove the webcam cable, lift up the connector from the logic board gently.
Altre 3 persone hanno completato questa guida.
