Salta al contenuto principale
Sony Smart Watch SW2 Display Assembly Replacement
Vincent Shiue
Vincent Shiue e 5 altri collaboratori
Ultimo aggiornamento il March 19, 2020
5 minuti
Facile
Attrezzi Non Corretti
Introduzione
Vai al passo 1
In this guide we will be taking the Sony Smart Watch SW2 watch out of its housing to remove its screen in order to reach the interior components. This process will only require a small tool with a flat edge.
Cosa ti serve
Strumenti
Mostra di più…
  1. Sony Smart Watch SW2 Display Assembly Replacement, Display Assembly: passo 1, immagine 1 di 1
    • Detach the smart watch from the band by pushing on the back of the watch housing.
    • The power button may fall out once the smart watch is detached.
    • Set aside the power button and watch band as they are no longer needed for further disassembly.
  2. Sony Smart Watch SW2 Display Assembly Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
  3. Sony Smart Watch SW2 Display Assembly Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
  4. Sony Smart Watch SW2 Display Assembly Replacement: passo 4, immagine 1 di 1
    • Set aside the detached LCD screen to access the battery.
    How can i find New sw2 screen
    Eren Can Gelen - Replica
    where can i find this lcd where can i find this lcd display
    Sherali Mahmudov - Replica
    where can i buy this lcd give me a link thank you in advance
    Jerry Geolin - Replica
Conclusione
To reassemble your device, follow these steps in reverse order.
Altre 3 persone hanno completato questa guida.
Vincent Shiue
Membro da: 01/22/18
265 Reputazione
2 Guide realizzate
IUPUI, Team S1-G5, Freund Spring 2018 Membro di IUPUI, Team S1-G5, Freund Spring 2018
IUPUI-FREUND-S18S1G5
3 Membri
2 Guide realizzate
1Commento della guida
whwre can I get the LCD screen for SW2?
faizal ahamed - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,148
