Salta al contenuto principale
Sony NEX-7 LCD Assembly Replacement
Jay Miley
Jay Miley e 7 altri collaboratori
Ultimo aggiornamento il May 7, 2024
5 - 10 minuti
Moderato
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
Strumenti
Mostra di più…
  1. Sony NEX-7 LCD Assembly Replacement, LCD Assembly: passo 1, immagine 1 di 1
    • Remove the two 3/32" #00 screws located next to the viewfinder using the Phillips #00 screwdriver.
  2. Sony NEX-7 LCD Assembly Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the two screws from the right side of the camera below the D ring:
    • The 5/32" upper screw
    • The 3/32" lower screw
  3. Sony NEX-7 LCD Assembly Replacement: passo 3, immagine 1 di 1
    • Remove two more 3/32" #00 screws from the bottom of the camera using the Phillips #00 screwdriver.
  4. Sony NEX-7 LCD Assembly Replacement: passo 4, immagine 1 di 1
    • Remove two more 3/32" #00 screws from the metal bracket on the left side of the camera using the Phillips #00 screwdriver.
  5. Sony NEX-7 LCD Assembly Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Unplug the orange ribbon cable on the top right of the camera next to the metal bracket by applying tweezers to the tabs on either side of the plug.
  6. Sony NEX-7 LCD Assembly Replacement: passo 6, immagine 1 di 1
    • Before pulling off the assembly, fold the rightmost tab of the flexible circuit board away from the metal bracket.
  7. Sony NEX-7 LCD Assembly Replacement: passo 7, immagine 1 di 2 Sony NEX-7 LCD Assembly Replacement: passo 7, immagine 2 di 2
    • The LCD assembly is attached with a concealed ribbon cable, so be gentle when you remove it.
    • The D ring brackets on either side are not attached, only held in mechanically. Once the LCD assembly starts to come out, they will detach.
    • Pull on the D rings on either side of the camera to start removing the assembly.
    • Once the brackets are cleared from black shell, take them off and set them aside.
    • Continue to remove the screen assembly.
  8. Sony NEX-7 LCD Assembly Replacement: passo 8, immagine 1 di 1
    • With the camera face down, move the assembly away from you to get a clear view of the wide ribbon cable.
    • Unplug the cable by applying tweezers to the tabs on either side of the plug.
    • Set the LCD assembly aside.
Conclusione
Jay Miley
Membro da: 04/22/14
5.253 Reputazione
13 Guide realizzate
Cal Poly, Team 10-55, Amido Spring 2014 Membro di Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Membri
36 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 100
