Salta al contenuto principale
Sony Cyber-shot DSC-W570 LCD Screen  Replacement
Thomas Plummer
Thomas Plummer e 5 altri collaboratori
Ultimo aggiornamento il 2 mar 2025
Nessuna stima
Moderato
Studente al lavoro
Prerequisite Mancanti
Introduzione
Vai al passo 1
This is a guide to replace dead pixels, cracked screens, and malfunctioning button terminals.
Cosa ti serve
Strumenti
Mostra di più…
  1. Sony Cyber-shot DSC-W570 LCD Screen  Replacement, Case Cover: passo 1, immagine 1 di 1
    • Begin by facing the camera bottom side up to reveal the two 2.93 mm long screws
    • Remove these two screws using a Philips #00 screwdriver
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: passo 2, immagine 1 di 1
    • Turn the camera sideways on its left side making sure the two 2.93 mm long screws are facing upwards
    • Remove the two 2.93 mm long screws using a Phillips #00 screwdriver
    • Keep all screws on stable surface to not loose them
  3. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: passo 3, immagine 1 di 1
    • Turn the camera on its right side making sure it is facing upwards
    • Remove the last two 2.93 mm long screws using a Phillips #00 screwdriver
  4. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-W570 LCD Screen  Replacement: passo 4, immagine 2 di 2
    • Face the device with the camera lens facing upwards
    • Now that all the screws are unscrewed, the plastic opening tool will be used to remove the front cover.
    • Gently pry off each corner of the cover to remove it
    • Once all corners are pried off, gently lift off the cover and place it on the side
  5. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-W570 LCD Screen  Replacement: passo 5, immagine 2 di 2
    • Flip the device, making sure the screen is facing upwards
    • The back case should now be visible and ready to remove
    • Use the plastic opening tool to gently pry all along the corners and sides of the camera.
    • Gently lift off the entire back cover and place it on the side
  6. Sony Cyber-shot DSC-W570 LCD Screen  Replacement, LCD Screen: passo 6, immagine 1 di 1
    • Taking off the previous cover will reveal the two cables connecting the LCD screen to the motherboard below the screen.
  7. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: passo 7, immagine 1 di 1
    • Remove the LCD screen from the side opposite the battery terminals.
    • Watch carefully for the two cords mentioned in the previous step. These will still be connected.
    • The side will flip up as shown in the next step.
  8. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: passo 8, immagine 1 di 1
    • Pull these two cords straight back to disconnect them from the respective housings.
    • Caution: The housing does not need to be moved or adjusted in any way. DO NOT pull the cords at an angle, it can destroy the cords and the housing. Pull Straight Back!
  9. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: passo 9, immagine 1 di 1
    • This is what the camera should look like after 2 cords and the screen have been removed.
    • The lens cord is being held to the side for a clearer view.
Conclusione
USF Tampa, Team 9-1, Brown Winter 2015 Membro di USF Tampa, Team 9-1, Brown Winter 2015
USFT-BROWN-W15S9G1
5 Membri
10 Guide realizzate
2Commenti sulla guida
And the screen replacement how??
Pau Roqué Robert - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,399
