Salta al contenuto principale
Sony Cyber-Shot DSC-W830 LCD Replacement
Addyson Salalila
Addyson Salalila e 5 altri collaboratori
Ultimo aggiornamento il 24 dic 2016
10 minuti
Moderato
Introduzione
Vai al passo 1
This will show you how to disassemble the camera and show you how to safely and successfully remove the LCD.
Cosa ti serve
Strumenti
Mostra di più…
  1. Sony Cyber-Shot DSC-W830 LCD Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 2, immagine 1 di 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 3, immagine 1 di 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: passo 4, immagine 1 di 3 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: passo 4, immagine 2 di 3 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: passo 4, immagine 3 di 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 5, immagine 1 di 3 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 5, immagine 2 di 3 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 5, immagine 3 di 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
    There is also a small corner piece, coloured the same as camera body, at the battery compartment corner which will also fall out. be careful not to loose it - it’s a bit fidly to fit back when re-assembling, but logcal. The Ifixit tweezers where a great help in locating it back on its pins.
    Nicholas Smith - Replica
  6. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 6, immagine 1 di 3 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 6, immagine 2 di 3 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 6, immagine 3 di 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: passo 7, immagine 1 di 2 Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: passo 7, immagine 2 di 2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 8, immagine 1 di 2 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 8, immagine 2 di 2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: passo 9, immagine 1 di 2 Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: passo 9, immagine 2 di 2
    • Push the bottom right corner of the LCD screen out and slide it to the right to release it from the clips.
    • Be careful when lifting the LCD screen; the ribbon cable will still be attached.
  10. Sony Cyber-Shot DSC-W830 LCD Replacement: passo 10, immagine 1 di 2 Sony Cyber-Shot DSC-W830 LCD Replacement: passo 10, immagine 2 di 2
    • Grasp the no-fuss ribbon cable and gently pull it out from the motherboard.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 17-1, Blackwell Fall 2016 Membro di USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Membri
6 Guide realizzate
5Commenti sulla guida
hii
plaz help me
tajbhatnagar - Replica
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Tamil Varshitha - Replica
Sony dsc s2000 model camera need
Display & lens unit
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 40
Tutti i Tempi: 4,840
