Salta al contenuto principale
Sony Alpha a7s II LCD Replacement
Jabari Montsho
Jabari Montsho e 2 altri collaboratori
Ultimo aggiornamento il November 5, 2024
10 minuti
Moderato
Introduzione
Vai al passo 1
The LCD screen can be pulled out to a couple of different angles. However, be careful when angling it because it does have restrictions. Doing so past those restrictions will break the LCD bracket holding it in place.
Cosa ti serve
Strumenti
  1. Sony Alpha a7s II LCD Replacement, LCD: passo 1, immagine 1 di 1
    • Orient the camera so that the LCD screen is facing you.
  2. Sony Alpha a7s II LCD Replacement: passo 2, immagine 1 di 1
    • Lift the LCD screen to unscrew the 2 screws on its underside.
    What is the screw size on these on the screen because I lost some and I am trying to replace it?
    KELLTEC 556 - Replica
  3. Sony Alpha a7s II LCD Replacement: passo 3, immagine 1 di 1
    • Unscrew the 2 screws on the bottom of the LCD screen.
  4. Sony Alpha a7s II LCD Replacement: passo 4, immagine 1 di 1
    • Carefully remove the back of the LCD cover.
    Before doing this step, you'll need to undo the ribbon cable that goes through the back of the LCD cover. On the ribbon cable connection to the LCD PCB, there is a flap to lift, then the ribbon can be carefully removed.
    Egrazil - Replica
  5. Sony Alpha a7s II LCD Replacement: passo 5, immagine 1 di 1
    • Carefully pull up the LCD front cover from the metal internal frame.
    • Be careful of the wire ribbon as it is fragile.
Conclusione
Altre 9 persone hanno completato questa guida.
4Commenti sulla guida
And the how do you change the LCD screen please ? How to remove it ?
timothee.ferreol - Replica
I have the exact same question, I need to change the screen with flex cable as well. Thanks, there isn’t a lot of info on the a7s 2, it’s all a7r out there
Viro Films - Replica
Hello. My LCD backlight stop working after water came into the camera (snow). With a flash light I was able to determine it is the backlight since I was able to detect some menu items on the screen. I bought a replacement LDC unit, my thinking was that the backlight itself was damaged and a new one would do the trick. After replacing the screen, I have the same probleme. So I suppose my problem come from deeper in the camera. The camera itself do not command the backlight to turn on. Is there something I can do? any more troubleshooting?
Thanks!
Jean-Philippe Archibald - Replica
What size screws!?
Alain Bucio - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 121
Tutti i Tempi: 12,123
