Salta al contenuto principale
Shark Cordless Pet Perfect Front Belt Replacement
Ben Dzugen
Ben Dzugen e 4 altri collaboratori
Ultimo aggiornamento il September 13, 2022
10 minuti
Facile
Introduzione
Vai al passo 1
If you are having a problem with your device's Front Belt, Here is a Step by step guide to replace a faulty or broken Front Belt.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: passo 1, immagine 1 di 2 Shark Cordless Pet Perfect Front Belt Replacement, Front Belt: passo 1, immagine 2 di 2
    • Remove the two 12mm screws from the front face plate with the PH2 bit from the tool kit.
  2. Shark Cordless Pet Perfect Front Belt Replacement: passo 2, immagine 1 di 3 Shark Cordless Pet Perfect Front Belt Replacement: passo 2, immagine 2 di 3 Shark Cordless Pet Perfect Front Belt Replacement: passo 2, immagine 3 di 3
    • Once the screws are removed pull the front face plate off. This will allow access to the belt and motor.
  3. Shark Cordless Pet Perfect Front Belt Replacement: passo 3, immagine 1 di 3 Shark Cordless Pet Perfect Front Belt Replacement: passo 3, immagine 2 di 3 Shark Cordless Pet Perfect Front Belt Replacement: passo 3, immagine 3 di 3
    • Lift the brush roller upwards towards you, and the brush roller should come out along with the belt.
  4. Shark Cordless Pet Perfect Front Belt Replacement: passo 4, immagine 1 di 2 Shark Cordless Pet Perfect Front Belt Replacement: passo 4, immagine 2 di 2
    • Remove the belt from the motor mount, and then replace with a new belt.
Conclusione
Ben Dzugen
Membro da: 02/02/17
383 Reputazione
3 Guide realizzate
USF Tampa, Team 16-2, Blackwell Spring 2017 Membro di USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Membri
11 Guide realizzate
2 Commenti
Nice and simple but where can we purchase the belts?
jmrlachance - Replica
My shark pet vacuum didn't come with lint brush roller. How do I get one. I buy these pet vacuum for friends/family. Please respond
Tina Cherney - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 45
Tutti i Tempi: 2,957
