Salta al contenuto principale
Shark Cordless Pet Perfect Battery Replacement
Ashley Calkins
Ashley Calkins e 5 altri collaboratori
Ultimo aggiornamento il September 13, 2022
3 minuti
Facile
Introduzione
Vai al passo 1
If you are having a problem with your device's Battery, Here is a step by step guide to replace a dead or faulty Battery.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Shark Cordless Pet Perfect Battery Replacement, Battery: passo 1, immagine 1 di 3 Shark Cordless Pet Perfect Battery Replacement, Battery: passo 1, immagine 2 di 3 Shark Cordless Pet Perfect Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the Dust Cap Container then remove the 7.5mm screw (with the PH2 Bit) from the battery cover.
    • Using a black spudger pry open the cover, and remove the cover plate.
  2. Shark Cordless Pet Perfect Battery Replacement: passo 2, immagine 1 di 2 Shark Cordless Pet Perfect Battery Replacement: passo 2, immagine 2 di 2
    • Once the battery cover is removed slide the battery mount upwards and pull it out.
  3. Shark Cordless Pet Perfect Battery Replacement: passo 3, immagine 1 di 3 Shark Cordless Pet Perfect Battery Replacement: passo 3, immagine 2 di 3 Shark Cordless Pet Perfect Battery Replacement: passo 3, immagine 3 di 3
    • Pull out the battery and then disconnect the battery at the quick disconnects.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 16-2, Blackwell Spring 2017 Membro di USF Tampa, Team 16-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G2
4 Membri
11 Guide realizzate
4 Commenti
Throw it away and buy new lithium Pet Perfect
John Carson - Replica
I changed the battery, it still shuts off after 1 second
Garry - Replica
It has a 2 year warranty, mine quit working at 2 years 10 months. Pretty expensive for only 34 months.
Ralph E Beaver - Replica
Mine still working after 3 (three)years and it was $45 at the time from Walmart. Wouldn't be cheaper to buy an other whole unit than waste $45 plus tax, plus work just on the battery pack like Amazon's Banshee ( read EXTRATERRESTRIAL ) battery pack of $45 plus tax ???
Aurel Tita - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 87
Tutti i Tempi: 14,846
