Salta al contenuto principale
Shakespeare Synergy Steel Titanium Fishing Reel Disassembly
Coen Herring
Coen Herring e 2 altri collaboratori
Ultimo aggiornamento il November 15, 2023
15 - 20 minuti
Moderato
Immagini Non Adeguate
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Hello, this is a simple guide of how to disassemble a Shakespeare Synergy steel titanium fishing reel.
  1. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly, Fishing Reel: passo 1, immagine 1 di 1
    • Remove spool cover.
  2. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly, reel: passo 2, immagine 1 di 1
    • Take off bottom cover, there is a small screw in the front of the cover. After that's removed just rotate clockwise to remove.
  3. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: passo 3, immagine 1 di 1
    • Remove release handle. There is a little pin in the place that is circled. It will need to be hit out with a tiny screwdriver and hammer. After that the handle will slide right out.
  4. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: passo 4, immagine 1 di 1
    • The spring circled needs to be removed with a flat head screw driver of a small pair of pliers. after that is removed the spool topper will fall right out. Also unscrew the reel handle (what's used to reel in the line).
  5. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: passo 5, immagine 1 di 1
    • Next, take off the snap on clip on the top and pull off the spool. Be sure to keep track of the order of the washers both plastic and metal.
  6. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: passo 6, immagine 1 di 2 Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: passo 6, immagine 2 di 2
    • Remove this center gear. Keep the alignment of the gears the same when you take it off.
  7. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: passo 7, immagine 1 di 1
    • Remove the crank shaft with the four screws that hold it in. Be sure that the alignment of the pins on the back side stay the same with the smallest pin facing down.
  8. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: passo 8, immagine 1 di 1
    • Next, remove the pinion gear that was sitting ion the area circled in red. Easily removed with pliers.
  9. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: passo 9, immagine 1 di 1
    • Remove the drag adjustment wheel by taking off the snap ring with a flat head screwdriver.
  10. Shakespeare Synergy Steel Titanium Fishing Reel Disassembly: passo 10, immagine 1 di 1
    • Finally, remove the center bearing. It is removed easiest by pushing two screwdrivers outwards on the inside of the bearing.
Conclusione
Coen Herring
Membro da: 08/29/23
211 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 39
Tutti i Tempi: 788
