Salta al contenuto principale
Seville Classics MSC10166 Disassembly
Queena Phung
Queena Phung e 8 altri collaboratori
Ultimo aggiornamento il January 20, 2025
Nessuna stima
Moderato
Foto Azione
Necessarie Immagini Migliori
Necessarie Più Immagini
Pallini!
Dettagli Mancanti
Introduzione
Vai al passo 1
This repair guide solves any rotation and vibration problems that the fan might have. The track at the bottom of the fan is the main source of rotation and vibration problems. Use the tear-down guide to remove all other components to get to the track.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Seville Classics MSC10166 Disassembly, PCB (Printed Circuit Board): passo 1, immagine 1 di 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Seville Classics MSC10166 Disassembly: passo 2, immagine 1 di 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 Disassembly: passo 3, immagine 1 di 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 Disassembly: passo 4, immagine 1 di 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 Disassembly: passo 5, immagine 1 di 2 Seville Classics MSC10166 Disassembly: passo 5, immagine 2 di 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: passo 6, immagine 1 di 2 Seville Classics MSC10166 Disassembly, Rotating Blade and Transformer: passo 6, immagine 2 di 2
    • In order to remove the fan blade pliers were used to remove the holding nut.
    • After the holding nut is loose, use the pliers to pull up to remove the nut.
  7. Seville Classics MSC10166 Disassembly: passo 7, immagine 1 di 1
    • Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
    • Use a pair of pliers to hold the nut at the bottom of the transformer, as you unscrew from left-to-right at the top of the transformer. After, pull up and remove both the screw and nut.
  8. Seville Classics MSC10166 Disassembly: passo 8, immagine 1 di 2 Seville Classics MSC10166 Disassembly: passo 8, immagine 2 di 2
    • Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer.
    • Remove screws by pulling them away from the base.
    • The transformer should be free after this step.
  9. Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: passo 9, immagine 1 di 2 Seville Classics MSC10166 Disassembly, Seville Classics MSC10166: passo 9, immagine 2 di 2
    • Clean the track, removing any obstructions.
    • Lubricate the track with grease.
Conclusione
Altre 2 persone hanno completato questa guida.
Queena Phung
Membro da: 09/26/12
114 Reputazione
3 Guide realizzate
Cal Poly, Team 15-46, Forte Fall 2012 Membro di Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 50
Tutti i Tempi: 11,355
