Salta al contenuto principale
Samsung Watch Active Sensor Array Replacement
Cosa ti serve
  1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: passo 1, immagine 1 di 2 Samsung Watch Active Sensor Array Replacement, Turn off the watch: passo 1, immagine 2 di 2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Watch Active Sensor Array Replacement, Remove the rear screws: passo 2, immagine 1 di 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: passo 3, immagine 1 di 3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: passo 3, immagine 2 di 3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: passo 3, immagine 3 di 3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: passo 4, immagine 1 di 2 Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: passo 4, immagine 2 di 2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Watch Active Sensor Array Replacement, Remove the back cover: passo 5, immagine 1 di 1
    • Remove the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: passo 6, immagine 1 di 3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: passo 6, immagine 2 di 3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: passo 6, immagine 3 di 3
    • Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
    • Carefully twist the opening pick to separate the sensor array from the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: passo 7, immagine 1 di 2 Samsung Watch Active Sensor Array Replacement, Remove the sensor array: passo 7, immagine 2 di 2
    • Remove the sensor array from the back cover.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Tobias Isakeit
Membro da: 03/31/14
134.079 Reputazione
189 guide realizzate
Tobias Isakeit - Repairability Engineer Membro di Tobias Isakeit - Repairability Engineer
Business
Membro di 1
1.151 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 44
Tutti i Tempi: 4,864
