Salta al contenuto principale
Samsung Rant Rear Case Replacement
Denise Cooper
Denise Cooper e 5 altri collaboratori
Ultimo aggiornamento il September 14, 2020
Nessuna stima
Moderato
Introduzione
Vai al passo 1
In order to gain access to the rear case, you must remove the back cover and battery. Be sure to have the necessary tools for removing the screws holding the rear case in place.
Cosa ti serve
Strumenti
  1. Samsung Rant Rear Case Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Rear Case Replacement, Rear Case: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
  3. Samsung Rant Rear Case Replacement: passo 3, immagine 1 di 1
    • Gently separate the rear case from the front case.
Conclusione
James Madison, Team 1-6, Allen Fall 2011 Membro di James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,164
