Salta al contenuto principale
Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement
Alexander Ulman
Alexander Ulman e un altro collaboratore
Ultimo aggiornamento il December 12, 2019
20 minuti
Moderato
Introduzione
Vai al passo 1
This is a guide to replace the Wi-Fi card on the Samsung Notebook 7 Spin NP740U3MK01US. However, it is extremely difficult to replace the Wi-Fi card itself so this guide shows how to replace the whole USB board that the Wi-Fi card is attached to. If you are unable to connect to a wireless network use this guide to replace your Wi-Fi card.
Cosa ti serve
Strumenti
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
Mostra di più…
  1. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 3, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 4, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 5, immagine 1 di 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 5, immagine 2 di 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 5, immagine 3 di 3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: passo 6, immagine 1 di 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: passo 6, immagine 2 di 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: passo 6, immagine 3 di 3
    • Use the Phillips #00 screwdriver to remove the two 4.5mm screws holding the cover plate in place.
  7. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 7, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 7, immagine 2 di 2
    • Remove the black ribbon cable by pulling up on the black cover and sliding out the cable.
  8. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 8, immagine 1 di 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 8, immagine 2 di 3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 8, immagine 3 di 3
    • Remove the three black and white cables by gently pulling on them.
  9. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 9, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: passo 9, immagine 2 di 2
    • Use the Phillips #00 screwdriver to remove the two 4.5mm screws holding the USB board down and remove the board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 814
