Salta al contenuto principale
Samsung NX500 Image Sensor Replacement
Eli Carcalete
Eli Carcalete e 2 altri collaboratori
Ultimo aggiornamento il 11 nov 2020
35 minuti
Moderato
Introduzione
Vai al passo 1
If your camera has been exposed to high heat or prolonged periods of time in high temperature conditions, your camera's image sensor could be shot. A bad image sensor can cause a very distorted image or in some cases even a completely black screen when turned on.
Cosa ti serve
Strumenti
Mostra di più…
  1. Samsung NX500 Image Sensor Replacement, Battery: passo 1, immagine 1 di 2 Samsung NX500 Image Sensor Replacement, Battery: passo 1, immagine 2 di 2
    • Pull the switch on the bottom of the camera back with your thumb.
  2. Samsung NX500 Image Sensor Replacement: passo 2, immagine 1 di 2 Samsung NX500 Image Sensor Replacement: passo 2, immagine 2 di 2
    • Push second switch(blue) forward with your thumb.
  3. Samsung NX500 Image Sensor Replacement: passo 3, immagine 1 di 1
    • Pull out battery.
  4. Samsung NX500 Image Sensor Replacement, Screen Side Encasement: passo 4, immagine 1 di 3 Samsung NX500 Image Sensor Replacement, Screen Side Encasement: passo 4, immagine 2 di 3 Samsung NX500 Image Sensor Replacement, Screen Side Encasement: passo 4, immagine 3 di 3
    • Open the screen exposing the hinge cover and place the plastic opening tool inside.
    • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
    • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
  5. Samsung NX500 Image Sensor Replacement: passo 5, immagine 1 di 3 Samsung NX500 Image Sensor Replacement: passo 5, immagine 2 di 3 Samsung NX500 Image Sensor Replacement: passo 5, immagine 3 di 3
    • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
    • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
    • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
  6. Samsung NX500 Image Sensor Replacement: passo 6, immagine 1 di 2 Samsung NX500 Image Sensor Replacement: passo 6, immagine 2 di 2
    • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
    • The casing should be removed easily; you shouldn't have to use much force.
  7. Samsung NX500 Image Sensor Replacement: passo 7, immagine 1 di 2 Samsung NX500 Image Sensor Replacement: passo 7, immagine 2 di 2
    • Locate the black ribbon at the bottom left of the camera's interior.
    • Place the plastic opening tool under the black ribbon connector.
    • Remove the cable by moving your plastic opening tool in a downward motion.
    • There is zero to little force needed to remove this ribbon.
  8. Samsung NX500 Image Sensor Replacement, Main board: passo 8, immagine 1 di 3 Samsung NX500 Image Sensor Replacement, Main board: passo 8, immagine 2 di 3 Samsung NX500 Image Sensor Replacement, Main board: passo 8, immagine 3 di 3
    • Lift the black latch of the left main ribbon connector using a wide-set plastic opening tool in a downward motion.
    • Use your fingers to disconnect the cable.
    • There are five ZIF cables total to be removed.
  9. Samsung NX500 Image Sensor Replacement: passo 9, immagine 1 di 3 Samsung NX500 Image Sensor Replacement: passo 9, immagine 2 di 3 Samsung NX500 Image Sensor Replacement: passo 9, immagine 3 di 3
    • Use the wide-set plastic opening tool to lift the latch on the right main ZIF cable in a downward motion.
    • Disconnect the cable using your finger.
  10. Samsung NX500 Image Sensor Replacement: passo 10, immagine 1 di 2 Samsung NX500 Image Sensor Replacement: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Locate the ZIF cable at the bottom of the main board.
    • Disconnect the cable with the tweezers by pulling it away from where the cable is connected.
    • Be careful not tug too hard on the cable as you can damage it.
  11. Samsung NX500 Image Sensor Replacement: passo 11, immagine 1 di 2 Samsung NX500 Image Sensor Replacement: passo 11, immagine 2 di 2
    • Locate the skinny ZIF cable on the left side of the main board.
  12. Samsung NX500 Image Sensor Replacement: passo 12, immagine 1 di 3 Samsung NX500 Image Sensor Replacement: passo 12, immagine 2 di 3 Samsung NX500 Image Sensor Replacement: passo 12, immagine 3 di 3
    • Locate the black cable connected at the top right of the main board.
    • Place the wide-set plastic opening tool underneath the gray connector and carefully pry it up.
    • It will easily pop up.
  13. Samsung NX500 Image Sensor Replacement: passo 13, immagine 1 di 1
    • Remove the 4 black 4-mm Phillips #000 screws located near each corner of the main board.
    • Lift the board out of the casing and carefully put it somewhere safe.
  14. Samsung NX500 Image Sensor Replacement, Image Sensor: passo 14, immagine 1 di 2 Samsung NX500 Image Sensor Replacement, Image Sensor: passo 14, immagine 2 di 2
    • Remove the three black 5-mm T6 type screws using a Torx screwdriver located along the metal casing of the image sensor.
    • The image sensor is very sensitive, be sure not to smudge the filter covering.
    • Pull the image sensor out and it can now be replaced.
Conclusione
Preparati per le riparazioni future
Acquista tutti
USF Tampa, Team 18-5, Blackwell Fall 2016 Membro di USF Tampa, Team 18-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G5
3 Membri
12 Guide realizzate
3Commenti sulla guida
Thanks for this, very helpfull.
I needed to replace the shutter assembly.
For this, next step is to remove the metal top of the camera (a screw on each side and 2 screws in the flash shoe below the spring).
After this the 2 screws on top of the shutter assembly can be removed.
The shutter assy can now be removed although it is somewhat easier if the tripod mount is removed first.
Piet van der Plas - Replica
Very helpful. Thanks for posting.
My mode selector is not changing mode as it should, it seems like a contact failure. What shoul I do?
Juan Prekop
prekop - Replica
thanks so much for sharing Well appreciated
dave_tjeng - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,024
