Salta al contenuto principale
Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement
Cosa ti serve
  1. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: passo 2, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: passo 2, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: passo 2, immagine 3 di 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  3. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Heat the right edge: passo 3, immagine 1 di 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  4. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Adhesive information: passo 4, immagine 1 di 2 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Adhesive information: passo 4, immagine 2 di 2
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  5. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: passo 5, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: passo 5, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: passo 5, immagine 3 di 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  6. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the right adhesive: passo 6, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the right adhesive: passo 6, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the right adhesive: passo 6, immagine 3 di 3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  7. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Heat the bottom edge: passo 7, immagine 1 di 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  8. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 8, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 8, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 8, immagine 3 di 3
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while working around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  9. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the bottom adhesive: passo 9, immagine 1 di 2 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the bottom adhesive: passo 9, immagine 2 di 2
    • Slide your opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  10. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Heat the left edge: passo 10, immagine 1 di 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  11. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 11, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 11, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 11, immagine 3 di 3
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  12. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the left adhesive: passo 12, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the left adhesive: passo 12, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the left adhesive: passo 12, immagine 3 di 3
    • Slide your opening pick along the left edge to separate the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  13. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Heat the top edge: passo 13, immagine 1 di 1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  14. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 14, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 14, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 14, immagine 3 di 3
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  15. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the top adhesive: passo 15, immagine 1 di 2 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the top adhesive: passo 15, immagine 2 di 2
    • Slide the pick to the top left corner to separate the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  16. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 16, immagine 1 di 2 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: passo 16, immagine 2 di 2
    • Insert an opening pick in the gap at the top left edge.
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  17. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the remaining adhesive: passo 17, immagine 1 di 2 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the remaining adhesive: passo 17, immagine 2 di 2
    • Slide the pick toward the bottom camera to separate through the remaining adhesive, stopping before you reach the power button.
  18. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: passo 18, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: passo 18, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: passo 18, immagine 3 di 3
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  19. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: passo 19, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: passo 19, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: passo 19, immagine 3 di 3
    • Use the pointed end of a spudger to pry up and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  20. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the coil adhesive: passo 20, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the coil adhesive: passo 20, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Separate the coil adhesive: passo 20, immagine 3 di 3
    • The wireless charging coil is lightly adhered to the battery.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
  21. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement: passo 21, immagine 1 di 2 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement: passo 21, immagine 2 di 2
    • Insert an opening pick between the top edge of the wireless charging coil and the frame.
    • Slide the pick toward the right edge to separate the remaining adhesive.
  22. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Unfasten the NFC antenna and charging coil: passo 22, immagine 1 di 1
    • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
  23. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Unfasten the loudspeaker: passo 23, immagine 1 di 1
    • Use a Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  24. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Unclip the loudspeaker: passo 24, immagine 1 di 2 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Unclip the loudspeaker: passo 24, immagine 2 di 2
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  25. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: passo 25, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: passo 25, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: passo 25, immagine 3 di 3
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
  26. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the battery: passo 26, immagine 1 di 2 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the battery: passo 26, immagine 2 di 2
    • Use your spudger to pry up and disconnect the battery press connector.
  27. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: passo 27, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: passo 27, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: passo 27, immagine 3 di 3
    • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the motherboard.
    • Repeat for the primary interconnect cable.
  28. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement: passo 28, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement: passo 28, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement: passo 28, immagine 3 di 3
    • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the charging board.
  29. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the interconnect cables: passo 29, immagine 1 di 2 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the interconnect cables: passo 29, immagine 2 di 2
    • Grab and remove the interconnect cables from the frame.
  30. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Unfasten the charging board: passo 30, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
  31. Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: passo 31, immagine 1 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: passo 31, immagine 2 di 3 Samsung Galaxy S23 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: passo 31, immagine 3 di 3
    • Insert the point of your spudger under the top right of the charging board.
    • Pry the charging board up from its recess until you can grab it with your fingers.
    • Pull the charging board toward the top of the device to remove it from its recess.
    • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
Conclusione
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and Samsung Self-Repair document (beginning page 10) to make sure your device is fully functional.
Altre 3 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
163.636 Reputazione
769 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.632 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 25
Ultimi 7 Giorni: 133
Ultimi 30 Giorni: 707
Tutti i Tempi: 5,793
