Salta al contenuto principale
Samsung Galaxy Note8 Touchscreen and LCD Replacement
ian mdx
ian mdx e 2 altri collaboratori
Ultimo aggiornamento il 17 lug 2024
40 minuti
Moderato
Guida fornita dalla comunità
Introduzione Migliore
Richiede Trascrizione
    • Insert a comment here
Linea Traguardo
Altre 25 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
fr en
100%
irlanda ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
ian mdx
Membro da: 06/30/16
9.101 Reputazione
17 Guide realizzate
10Commenti sulla guida
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - Replica
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - Replica
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - Replica
Will the phone remain waterproof after this repair?
cj-dm - Replica
The phone will only remain waterproof if you re-apply the correct waterproof seal, and even then I wouldn’t trust it.
Jack Donovan -
Is there a way to buy an OEM NOTE 8 front glass replacement instead of the Chinese crap on eBay?
Thanks
hakim laksiwar - Replica
Just saw our question while preparing to change a Note 8 and I do not know if you received and answer. GadgetFix or Digital Supply USA(who also uses GadgetFix as a supplier) sell Samsung(original OEM) screens the cheapest so far.
Bryan Solo -
Is that copper colored piece supposed to stay on the phone after removing glass and touch screen?
Bill Stark - Replica
My screen is jumping around and won’t allow me to touch or navigate my screen?
Delucious Anderson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 67
Tutti i Tempi: 25,023
