Samsung Galaxy Grand Prime Digitizer and LCD Replacement
Cosa ti serve
Strumenti
Mostra di più…
Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
Go around the edge of the back cover to completely remove it.
Remove the old battery by lifting up on the thumb tab.
Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
Disconnect all flex cables and remove the motherboard and the front-facing camera.
The display assembly is attached to the frame with adhesive.
Insert an opening pick between the glass and the frame in the gap above the front-facing camera bracket. Begin to slice through the adhesive on the top bezel of the phone.
On the right corner, gently twist the pick up and down to further separate the adhesive, then insert it as shown between the LCD and the frame.
Insert a second pick into the gap between the frame and the display flex cable.
Move both picks towards the bottom of the phone to separate the adhesive on the sides of the screen.
Separate the adhesive on the bottom half of the phone, flip it around, and separate the frame from the screen assembly starting from the bottom.
Ensure the display cable can freely move through the hole in the frame.
The LCD and digitizer are not glued together with LOCA glue, but just with adhesive around the edges of the digitizer.
The digitizer is connected to the LCD with a flex cable. Flip up the bottom half of the connector.
Apply gentle heat to the IC. Insert a pick as shown and separate.
To separate the LCD and digitizer, apply gentle heat to the front of the assembly and gently slide picks along the edges of the LCD.
Altre 6 persone hanno completato questa guida.
